Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Oh oh, new scratch built project underway
Old 11-03-2006, 09:21 PM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
Originally Posted by Nightfire
...are you gonna leave the sides pretty "flat" or make a pretty accurate replica with rounded corners and the roof dripline etc...
Well, I HOPE to end up pretty close to Malc's drawing...which means it will also be pretty close to the original Defibrillator. I'll be doing more of the accent lines (like around the door and roof line) and recessed areas (like around the rear tires) than I did on the roadster. I'm also anticipating that I'll put a little greater crown into the sides than I did with the roadster. I guess the short answer is I'm going to try to get it as accurate as I possibly can and improve a bit on the techniques I used for the rat.
Always learning...and sharing what I've learned.
