Oh SHOOT!
Boy am I in trouble! I have been working on this car on and off for months. It is a 1964 Ford Fairlane 500 Sports Coupe, 289 engine. I am adding power steering and air conditioner. I have an Eaton cast iron power steering pump. I have installed the Eaton Pump, but don't know how or where to put the air conditioner compressor (with the power steering pump mounted). I have mounted the compressor (it uses the same bolt holes as the power steering pump), but I can't figure out how to have both (at the same time). This year model seems to be hard to add modifications to. I don't know if I am going to be able to crawl out of this hole or not! I probably need to find someone with the same car as mine that came with this stuff factory equipped so I can be able to know exactly what I need. Right now I am just wasting money trying different stuff I pick up here and there. Maybe there is someone out there that will hear my cry and give me some help. It would be great if I could find someone that has this car with this stuff factory equipped...Help!!!!!!!!!!!!
64 tight spot
Why change. MAYBE you will get lucky-somebody else did it. Maybe a Lincoln has pieces that change out. Leave something out. Most likely you will have to make it If somebody doesn't come up with a specific answer, you make it- talk about that when or if all else fails. good luck mark
Alan Grove has brackets for A/C and power steering. Check it out www.alangrovecomponents.com
| Recent General Rodding Tech posts with photos |
| 351C acting up again...shoot me now | Steve-0321 | Engine | 6 | 10-05-2005 02:15 PM |
| I shoot the base today | ptcamaro | Body - Exterior | 14 | 10-04-2005 08:58 AM |
| Spot weld driller Shoot out! | MARTINSR | Body - Exterior | 5 | 05-30-2005 05:46 PM |
| What can I shoot with a 1.4 nozzle | antiquecar | Body - Exterior | 19 | 03-02-2005 09:16 PM |
| I could shoot myself! | cajunstang | Hotrodders' Lounge | 3 | 04-25-2003 06:20 PM |
