Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - OHV conversion
Thread: OHV conversion
Old 12-07-2012, 07:30 AM
timothale timothale is offline
Wiki Edits: 27
engineering dimensions ?
So we still don't know if the aust Hemi head would fit or with some modifications would work. Time to try to get some head gaskets and see if the bores and bolt holes line up. The guy that had the Stude head on his T use a 1/2 aluminum plate with studs for the head and holes to bolt to the T block. My old neighbor that had the Boss head on his iron duke changed and started sawing small block chevies in half to make V 4's for his circle track cars. Just how much work do you want to do? Find an import Hemi saw it in half, then weld the head back together ?
