Oil for 10 bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2005, 06:06 PM
lluciano77's Avatar
Oil for 10 bolt
What weight oil should I use in my non-posi 8.5" 10 bolt? How many quarts do I need to fill it?
Old 10-17-2005, 06:16 PM
48ChryslerRodder's Avatar
Stuck in the past.
Oil for 10 bolt
I've always used 90W gear lube. You can buy it by the quart at your local auto parts store. As for how much I can't give a specific amount but have always checked the level at the fill hole by sticking a finger in and bending the tip down. If I had lube on the tip then there was enough in the differential. I have also heard that you can fill until it is level with the fill hole, but Maybe some of our other members can share their experience.
Old 10-17-2005, 10:27 PM
75W-90, 80W-90, or 85W-90 should be fine. Capacity is 4-1/4 pints.
Old 10-18-2005, 12:33 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
defintiely synthetic...
new engine, oil pressure probs montea Engine 35 06-02-2006 12:37 PM
Bolt and oil question? HemmiGremmie Engine 8 11-12-2004 07:52 AM
No oil pressure cleancut Engine 12 04-30-2004 10:35 AM
Tip of the day on oil additives that you need to read mcgyver-ky Engine 10 04-19-2003 05:17 AM
