oil adaptor for bbc by pass or... - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2007, 03:35 AM
malibu396's Avatar
i still have the canister type oil filter on my 396 1968 (motor still in parts).
is it better to use a adapter with by pass system or a full filter system
motor has a new stock m77 pump
also there came a purple spring with the pump is it wise to
put that spring in the pump.
motor gets a re-ring kit and new bearings and cam bearings
motor 9.5 comp
280/290 .501/527 cam
ported heads
stock exhaust for now and intake
thanks
Old 12-04-2007, 07:02 AM
Holder350's Avatar
Auto Parts Professional
The purple spring is to make the pump into a high pressure pump, I wouldn't put it in because your installing new bearings and that will tighten the motor back up.
As far as the oil filter goes the only reason to use a relocation kit is if there are clearance problems, but I would HIGHLY recommend an adapter to use a spin on filter. The reason should be apparent about the 3rd time you change the oil, I for one do not like being covered in oil every time I change it.
And the spin on filters are alot cheaper than the cans! Just my 2cent
Holder350....
Doc, we will all miss you. RIP
OH poopy... Overheated and no oil...**** Warrant Engine 33 11-12-2006 09:23 PM
Oil filter Super Magnets? Jag Daddy Engine 59 02-01-2006 07:36 PM
Mysterious Oil Leak DoubleVision Engine 4 09-01-2004 03:30 PM
383 stroker still pass oil by..... TVR383 Engine 13 10-27-2003 07:14 PM
Tip of the day on oil additives that you need to read mcgyver-ky Engine 10 04-19-2003 05:17 AM
