Oil adaptor and Starter bolts - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2003, 12:39 PM
1st que: I have a 350 small block and I am putting a oil filter adaptor so I can install a spin on filter, my problem is the 2 attaching bolts that attach my top adaptor are way to short, or do I have the wrong adaptor? I guess I could find 2 longer, but I thought this is the correct fit! 2nd que: I am installing a later style starter (small body type) and where would I find the two correct length bolts to mount the starter? Ring gear is a 168tooth.
Old 12-26-2003, 03:16 PM
Dave E Shank's Avatar
HEY 39: I don't know about the filter adapter, my 350 has a spin on filter. The starter bolts are the same length as the OEM, I just used same bolts.....DAVE
