Oil Around The Spark Plugs?????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2007, 10:50 PM
88 BERETTA GT
I just pulled out my spark plugs, and there was oil build up around the spark plug not down inside the plug! and then i pulled out the second one and it had a build up on it of some type... Can somebody tell me about the oil build up?... I guess i just need to do a good tune up on all Six plugs!... LET ME KNOW!!! been workin on this car for 4 weeks now, and nothing yet... I just found out about all of this build up on the spark plugs today!... So maby that was the problem all along!... SOMEBODY LET ME KNOW!!! P
Old 03-14-2007, 11:47 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Leakey valve cover gasket, OR leaky Oil pressure sender unit most likely is the culprit..
If it has been a LONG time since your engine was LAST tuned, that is the first BEST place to start..New plugs, module, coil, wires, Cap, Rotor, fuel filter (s), air filter, pump pressure and volume test, compression test, (125 to 150 /- 10% per hole) , code scan (if applicable)
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
oil leak rb8179 Engine 11 06-03-2006 03:07 AM
Jiffy lube rant: what would you do? killerformula Hotrodders' Lounge 35 02-16-2006 06:07 PM
Spark Plugs on a 1999 grand prix rbfpezcore Engine 9 11-30-2005 09:37 AM
Oil gallery plugs and loose cam? dutch paul Engine 4 08-08-2005 04:49 PM
what spark plugs are best? 72 chevy elcamino Engine 4 07-12-2005 08:59 PM
