Oil bath Air Cleaner.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2010, 02:22 PM
I was wondering what kind of weight oil I should use and how I should properly clean it. The oil that sits in there now is orange in color which worries me that there is rust in it. Is this true, or is there a special oil that is orange in color that is specifically used for these filters???
Thanks!
Old 05-04-2010, 03:13 PM
bondo's Avatar
Ayuh,... Clean it in a Parts Washer... It gets filled with motor oil...
Old 05-05-2010, 09:10 AM
Frisco's Avatar
Glad To Be Here
Older vehicles that used oil bath air cleaners used 30 wt. oil. To clean, simply pour out the old oil into a proper container to be disposed of. Use solvent and a rag to clean the remaining residual oil from the air cleaner housing. Let it air dry or blow it off with compressed air. Re-fill with new oil to the level mark (usually only a few ounces at the most. Just barely covers the bottom surface about an 1/8 " or so).The newer 'paper' filters do a much better job and can easily replace the oil bath style air cleaner.
Fresh air respirators 2stroketurbo Body - Exterior 26 02-15-2007 06:41 PM
Need help with air cleaner Dingman Engine 2 09-21-2006 09:43 PM
Air cleaner advice. ScreamingEagle General Rodding Tech 2 09-18-2006 10:59 AM
oil leak rb8179 Engine 11 06-03-2006 03:07 AM
