Oil blowing out of dip stick tube - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2013, 04:11 PM
Last journal entry: supercharged vw 1600 T-1
I have a stock 4.3 compression is between 140-145. Above idle oil comes out the dip stick tube...Any ideas ?
Old 06-17-2013, 04:58 PM
BOBCRMAN@aol.com's Avatar
Yes, I had a beater 2-dr Blazer. Started blowing dip stick and the oil fill plug. Turned out to be the passage near the front of the throttle body in the front of manifold that gets plugged with carbon.. Clean it out and run another hundred thou miles..
The Following 2 Users Say Thank You to BOBCRMAN@aol.com For This Useful Post:
Richiehd (06-17-2013), scarecrow37209 (06-23-2013)
Old 06-17-2013, 06:17 PM
jokerZ71's Avatar
Wrench Turner
If that is the cause,you need to take care of quik befor you drive it a lot.It could blow all your gaskets & seals.I found out the hard way.
Old 06-17-2013, 06:57 PM
Ok,what should I clean it out with ?
Old 06-17-2013, 07:39 PM
jokerZ71's Avatar
Wrench Turner
Take the TB off.Under the bottom,you should see a passage.Spray it good wit carb cleaner w/ the straw.You may need to let it soak.A small soft brush,or,if it's really hard,you may need a small pc of wire or a small drill bit.On the intake,the same thing,but,don't let any of the crud get into the intake.A shopvac helps.Also,ck your PCV valve & hoses to be sure it is working.Pull your PCV valve & shake it.It should rattle.Place your thumb over the end with engine running.You should feel vacum.
Old 06-17-2013, 07:58 PM
bubbahotep's Avatar
Sounds like the PCV line or PCV valve is clogged. The pressure in the motor isnt getting vented back into the intake, instead the pressure is pushing out of any hole it can find.
oil dip stick tube stuck 394ci engine bigluke Engine 1 08-27-2009 09:39 PM
I need a dip stick tube, WHERE to find it??? TooMany2count Engine 4 05-20-2009 01:33 PM
Oil dip stick tube JOEPOISON Engine 3 04-21-2009 05:50 PM
HELP! Can't get the trans dip stick tube in 67Camaros-n-BigD Transmission - Rearend 2 11-06-2005 07:42 AM
Tranny dip stick tube gilby246 Transmission - Rearend 2 05-11-2005 01:07 PM
