Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Oil breather cap
Old 09-30-2007, 02:47 AM
aka Duke of URL
Originally Posted by viking
the pic is where i unhooked my hose from my oil breather to my air cleaner and plugged in a oil breather filter unsure if this is how it should be installed if not please correct me
You have the correct basic idea and it is OK if you are not concerned about appearance.
just so i understand what your talking about when you say a closed system since my oil fill cap is closed i need to run a oil breather cap other wise i need to find an oil fill cap that is breathable.
if i understand you correctly.
Correct. The easiest and cleanest way out is to find a suitable open oil filler cap (will have a filtering element in cap).
That cap is the fresh air ingest side of the PCV System. The crankcase needs a fresh air source to operate properly.
