Oil Burning - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2005, 11:40 AM
Oil Burning
Mayby someone could shed some light on what is happening.When driving down the road,55 or 75 m.p.h.,the right exhaust will blow blue smoke.This happens intermittingly,sometimes every mile,sometimes every 10 miles.I pulled the valve cover and the return holes to the pan are clear.It does not smoke after setting and upon start-up.#4 plug was oiled up but not #6.#2 & #8 could not be checked without removing headers.I was hoping to find a plugged oil rerturn but did not.Any remedies?,short of pulling the heads or a complete rebuild.Thanks
Old 08-08-2005, 12:28 PM
poncho62's Avatar
Wiki Edits: 5
Sounds like a real bad oil seal in #4 cylinder.....................does it smoke worse when decelerating?
Old 08-09-2005, 06:51 PM
oil burning
No Poncho62 ,thank you for reply,but it does not smoke upon de-exhaleration,I talked to a buddy of mine,he told me to see if mayby my trans. modulator might be bad,allowing fluid to get sucked into carb,35OLDS
Old 08-09-2005, 07:29 PM
kstagger's Avatar
I just replaced the modulator in my wife's old malibu - it was blowing white smoke alot, and I pulled the vacuum line going to the modulator and transmission fluid dripped out.
if you are blowing blue smoke, then it probably is motor oil -
valve cover leak? Valve seals?
Kevin
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 06:14 AM
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 07:39 AM
Oil Temperature and oil types (long) TurboS10 Engine 36 03-01-2005 01:51 PM
Burning oil too much novadan Engine 5 09-09-2004 08:37 PM
Should I change my oil? 48Man Engine 2 01-29-2003 07:28 AM
