oil burning after sbc short block rebuild
What can be the cause of my sbc 400 burning oil out of the # 5 cylinder???
It was rebuilt as a short block, while using the stock heads. The first crank up it rain perfect. It even drove perfect (city wide). After about 50 miles, I took it on the interstate. It was maybe an 45 min to an hour driver doing 70 mph @2000 rpm's. Made it to my destination with no problems. On the way back, 40 mins in the trip I noticed a change in the sound of the exhaust. Oil pressure still reading fine, water temp also. Pull at the local gas station, and its running like a train. White-ish gray smoke is slightly puffing out of the driver side pipe. Now it feels like its running off 7 cylinders, won't hold a idle in drive, and is hesitating bad. Any help on what can possible be wrong??? |
#5 plug has oil on it. Could it be since the compression jumping back to normal (new moly rings) it could have blown a bad stem seal? Or something in that manor?
Pull the plugs and do a compression test. Probably end up pulling the heads eventually. Did you have the heads magnafluxed and rebuilt, or slap on used heads?
could be blown head gasket,happend too me once
Bogie |
Don't pull the heads off yet.
When you get a chance, do a leak down test. If you don't have a leak down tester, use a compression checker hose and apply air pressure to the cylinder with the valves closed, remove the radiator cap before applying the air pressure. If air is escaping from the open radiator, then you possibly have a cracked or warped head, or a blown head gasket, or a cracked or warped block.
If you have no leaks there, then there is a very good possibility that an intake gasket is not sealing and sucking oil in from the lifter valley. I hope this helps. James. |
400s crack a lot but the guys are right first leak down test it,if it back fires then ya flat cam and lots of metal in the oil
| Rebuild or Short Block my subaru 2.5DOHC | sjkonyndyk | Hotrodding Basics | 9 | 03-15-2011 06:39 PM |
| to rebuild or order a short block | sam_bo3 | Engine | 6 | 06-12-2009 01:12 AM |
| sbc burning oil | derekg383 | Engine | 30 | 11-03-2008 01:13 PM |
| what does a 400 sbc short block weigh? | 406 ss monte | Engine | 2 | 10-18-2008 04:23 PM |
| Help on recent 383 rebuild burning oil | y2k600f4 | Engine | 33 | 10-15-2008 07:45 PM |
