Oil Capacity for a 700-R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2002, 08:33 AM
Post Oil Capacity for a 700-R4
How much oil does it take to fill a 700-R4 transmission when I change the filter and gasket?
Old 05-05-2002, 09:28 AM
Post
You will only change about 4 qts when changing the filter and gasket.this is only about 40% of the total capacity so change it frequently.Many transmission shops have a machine to change the fluid which will get more of the fluid changed.If your fluid is dirty you may want to consider this option.
