Oil change in compressor
I need to change the oil in my compressor and the manual calls for a "Air compressor oil such as SAE-30". It is a Craftsman Two Stage. Would it hurt to use a synthetic oil or should I stick to the basic SAE-30.
oil for compressor......
Hi,go to a NAPA auto parts and get their compressor oil,ive been using it for years and no problems. take the fill cap out before the drain plug.
my compressor manual says to not run motor oil, and that it must be air compressor oil.. so I use Cambbell hausfeild compressor oil which is str8 30 wt but much diffrent than the str8 30 wt I run in the mower
You can get a synthetic compressor oil.
Compressor oil.com has oil reccomendations posted by manufacturers. I buy mine by the gallon from Jim's Air Compressors in Phoenix Az. For years we used 20 or 30 wt engine non detergent motor oil. But these were in the old low rpm compressors. The newer high rpm compressors might benefit from synthetic compressor oil.
This is just my opinion, I would think that the smaller compressors that are pressed to keep up and thus often exceed their duty cycle would benefit from synthetic oil. The reason is, and again this is just my opinion and nothing more than an opinion, is that these things usually get quite hot and synthetic oils generally do better than conventional oils at higher temperature.
Amsoil makes several different weights of synthetic compressor oil. I have the PCK ISO 100 in mine which runs from 0*F to well over 90*F no problem. Most likely you will only need a couple of quarts so the price difference between regular & synthetic will be less than 5.00. In my case the synthetic was actually cheaper than the Mobile Rarus 427 which is not nearly as flexible temp wise.
I do not know about the benefits but when I got my new Ingersall Rand 7 1/2 the paper work said that after the breakin period using their syn oil would increase the warranty from I year to three years...
Rich |
if it's chinese (easier to replace than service), doesn't see a lot of use, or you're financially pinched, use regular 30wt non detergent oil. Most oil companies make the stuff, you don't see it a whole lot though.
If it's used a lot/duty cycle exceeded a lot, or something you want to last a lifetime and pass down to the kids and have them pass it on, or are feeling generous, get the same grade synthetic oil, such as amsoil. |
I posted this on another compressor thread - might want to think more about the oil you are using...
...and make sure it's for air compressors!!! |
| Recent Garage - Tools posts with photos |
| Is it no good to have a High volume oil pump? | Calderone | Engine | 17 | 01-31-2008 05:26 PM |
| Environmentally friendly honing fluid. | F-BIRD'88 | Engine | 16 | 07-01-2007 10:06 AM |
| oil leak | rb8179 | Engine | 11 | 06-03-2006 03:07 AM |
| Oil Preshure | ve3ham | Engine | 9 | 10-28-2004 02:36 PM |
| A little humor | Kevin45 | Hotrodders' Lounge | 8 | 10-21-2004 12:47 PM |
