Oil clearence on crank - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2002, 06:44 PM
Talking Oil clearence on crank
My trusty Plastigauge says I have .003 oil clearence on my new crank. Specs say .002, so now what? <img src="confused.gif" border="0">
Old 11-20-2002, 07:03 PM
BOBCRMAN@aol.com's Avatar
Post
if you have .003 on the rear main you are ok, if you have .003 on the others you can run the crank but use a high volume oil pump.if the crank is std you can get .001 under bearings,the only other alternative is to have the crank turned to the next undersize and tell them you want it in the middle of the specs.
Old 11-20-2002, 09:08 PM
Talking
Here is what they are. Rear, 2.447. The rest, 2.446. Grind my new crank, Great. They know the freight kills me, or maybe they figure no one checks them. How mickey mouse is buying the 4 .001 bearings? I am running a HV oil pump. The rod throws are OK, they guage at .003. They miked at 2.098.
Old 11-21-2002, 05:29 AM
SAE Member; ASE Master Cert
Post
The -.001 bearings are not Mickey Mouse at all, many engine builders use them to get the oil clearance "right on". What brand of crank are you using? You didn't say what engine you have, but I am assuming that it is a 350" Chevrolet, based on the specs you posted. Anyway, if we are talking about a 350 Chevrolet, then your crank is somewhat out of specs. The journal sizes should be 2.4478"-2.4488" for the thrust bearing and 2.4483"-2.4493 for the other four. You will probably not find anyone who stocks only the plain shells in -.001 size. Will probably need to get the whole set in -.001.
EDIT: Even though .003" seems like a lot of clearance (and it is), you are actually within specs. The recommended oil clearance for 350" Chev. is .0011"-.0041" for the thrust and .0006"-.0036 for the others. I agree with Bob, if you go with the .003" clearance, then a high volume oil pump should be used.
[ November 21, 2002: Message edited by: engineguy ]
[ November 21, 2002: Message edited by: engineguy ]</p>
Old 11-21-2002, 01:34 PM
4 Jaw Chuck's Avatar
Post
0.003" is fine. Put it together and don't worry about it.
BTW I consider 0.0025 perfect, your close enough.
— Han Solo
