Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - oil on clutch and fixing sbc
Old 04-01-2013, 05:33 PM
ssmonty ssmonty is offline
Have you had a good look at the oil pressure(sending unit) port next to the distributor? From there it can leak down onto the belhousing for sure(ask me how I know). Not sure if there is enough gap between the bell housing and the block, but there's for sure no gasket.
It sometime seems I can never get that 1/8" pipe fitting tight enough with out it hitting something.
ssmonty
