oil coming out of the oil breaher
I have a 350 chevy engine,with the pvc valve on one valve cover and the oil fill and the oil breaher on the other.I think that the engine is about 1970,oil comes out of the oil breaker when the engine is running.When the oil comes out it falls off onto my exhaust causing it to smoke---what can I do
If the PCV system is plumbed correctly w/no vacuum loss between the carb and the valve and the PCV valve is working as it should and you're still getting that much blow by, it prolly time for a rebuild.
Be sure the oil level isn't too high and the grommets are tight, hose fits tight, no vacuum leaks. |
| oil coming out of breather | Pupsvette76 | Engine | 9 | 12-08-2012 03:12 PM |
| Vapor coming fro mthe breather and oil cap but not oil....????? | 76 elco | Engine | 8 | 07-06-2007 04:35 PM |
| oil coming out exhaust | mmartin1872 | Engine | 9 | 03-28-2006 08:37 PM |
| Oil coming up one side only..help! | TVR383 | Engine | 5 | 05-02-2004 09:35 PM |
| oil coming out of pcv | joefromcocomo | Engine | 3 | 02-13-2003 01:47 PM |
