Are there proper baffles in your valve covers? If there arent baffles some oil may be sloshing up that way. If there are and excessive oil is still coming up, I had the same problem. It was due to blowby from the piston rings. I am now in the middle of rebuilding my engine. Is your engine burning any oil? Is there oil pushing up into the pcv also?
Steve |
http://store.summitracing.com/partde...5&autoview=sku
You could try these. I had a problem with my PCV sucking up oil until I installed these. |
Doc here,
You need Baffles in the valve covers, AND a Vented Oil filler cap..Oil will find it's way out unvented/unbafeled holes if the crankcase remains under constant pressure. Check that the PCV you have is Correct for the engine you have..that may be a problem also. Doc.
Aftermarket Solutions Electronic & Electrical Innovations |
I replaced the breathers with Moroso breathers with no PCV, and I installed the "baffled" grommets. I haven't had a chance to drive it yet because it's been raining the past couple of days. I should beable to get it out by the weekend.
Charlie |
Gosh I miss DocVette-
I took it out and drove it for about 2 miles or so. It seemed OK. The cast aluminum GM valve covers dont have provisions for a baffle. I don't know why they don't. I'm hoping the "baffle" grommets will do the job over the long term.
Charlie |
you need one pcv and one return
pcv in one cover and return in other cover cross ventilation return needs to be filtered somehow or another if you look at a stock untouched engine you will see it is set up this way and it is for a good reason since 1968 they are all this way |
| Valve Lash adjustment | hiball | Engine | 36 | 05-11-2009 10:12 AM |
| silicon valve cover gaskets disappointing | rapsag | Engine | 10 | 05-01-2006 09:12 PM |
| 94 GM 3800 oil pump pressure spring and valve | motoxracer | Engine | 2 | 03-14-2006 08:12 PM |
| oil being sucked threw the pcv valve on my 350 sb.. | Robbie | Engine | 23 | 05-08-2004 09:12 AM |
| Condensation in valve cover breathers !! | markn | Engine | 6 | 04-18-2004 02:16 PM |
