Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Oil coming up one side only..help!
Old 05-02-2004, 04:03 PM
machine shop tom machine shop tom is offline
King of my Man-cave.
Did you use a shaft to drive the oil pump without the distributor housing on it? If you did, the oil didn't get to the right lifter galley because the distributor housing wasn't there to complete the galley passage. Try priming it with a primer that includes the distributor housing.
