oil consumption
5000miles on a 388 sbc. does not foul plugs .no visible smoke . no pcv.breathers only'no "spatter" out of them . compression:165 /170. leakdown test:2#loss@80psi. what elsedo you guys reccomend I check/test to findout where I'm losing a quart of oil every 500 miles? thanks in advance!
Oil Consumption
NEW [at time of build ]brodix ik200
BSE Racing Engines |
oil consumption
15w40 w/comp break in for first 500 mi. used mainly as a cruiser @23-2400rpm k-b claimer pistons -grant rings [cast] no idea what finish however,machine shop has good rep and they had rings. thanks engineczar,thats exactly what I meant.
I hope you meant conventional oil. If your running synthetic now it could be it`s not broken in well enough. I break mine in the first 3000 miles with conventional oil before going to synthetic. If you did the break in with conventional disregard this post.
perhaps I should add this a 6" rod motor [piston pin up in the oil ring] .yes , rotella t[supposed to have more zddp ?!
| Smoke'n motor | Red neck blazer | Engine | 25 | 06-09-2009 02:32 PM |
| oil change- step by step instructions for women and men | Fireball | Hotrodders' Lounge | 38 | 08-30-2008 07:39 AM |
| Windage trays | ernkazern | Engine | 25 | 09-18-2007 03:49 PM |
| Oil Change | THX_138 | Hotrodders' Lounge | 25 | 12-20-2006 03:01 PM |
| Excessive oil under valve covers in SBC? | TVR383 | Engine | 13 | 11-21-2005 12:48 AM |
