If its not the pcv sucking it away. Check to see if the rear intake rubber has squished out of place. Oil can run down the back of the block, over the back of the tranny, and the drive shaft will spray it all over the place. If this happens it usually doesn't leave a puddle. You should see oil all over the rear of the car.
