oil consumption - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2005, 07:38 PM
4doorjoe's Avatar
oil consumption
Hi guys i have 350 sbc fresh motor and seem to going through a lot of oil oil for some reason but it does not smoke or smell just goes i have gone through as much as a half a litire in a day now the only thing i can think of are my valve vovers the one for the pcv valve side is not baffeld could it sucking oil from there any help welcome
Joe sammut
Old 07-03-2005, 07:41 PM
oil
check for leaks, big puddles or other means for oil to go away.
Old 07-03-2005, 07:44 PM
4doorjoe's Avatar
oil consuption
there is not even a drop i put clean cardboard down on ground after every ride not a drop
Joe sammut
Old 07-03-2005, 07:59 PM
poncho62's Avatar
Wiki Edits: 5
Well, if it's not leaking it, it has to be burning it. If the PVC has no baffle around it, it may be sucking oil into the carb and burning it that way. Otherwise, it looks like bad rings. Generally, if it is burning that much, you would see smoke.
Old 07-03-2005, 08:02 PM
Jmark's Avatar
If you have non-stock valve covers, most have bad baffles and will let a lot of oil go right into the PCV valve and on into the engine. The smoke probaby won't be noticable but its constantly pulling in small amounts and burning it.
Mark
Old 07-03-2005, 08:29 PM
Fast Orange's Avatar
How many miles are on engine since rebuild?Some rings have a break-in period during which oil consumption can be high.I did a 302 Ford that burned 1 qt.of oil every 500 miles for the first 2500 miles.After that,oil consumption decreased to virtually nothing between oil changes at 3000 miles.I believe I used moly rings on that one,with a smooth surface finish in the cylinders.I was told afterwards that I should have left a rougher surface after honing.The engine had over 100,000 miles on the rebuild when I finally sold the pick-up,and it still wasn't burning oil,so it was just fine after it finally broke in.
I also swung an engine for a customer that the rebuilder had put std. rings in a .030 over bore.That engine never stopped smoking.To keep the customer happy on this one,I wound up pulling the engine and re-installing it for nothing.Needless to say I never used that rebuilder again,even though he repaired his mistake.
Just a couple of things to keep in mind,George
Old 07-03-2005, 08:39 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
If it was blowing out around the valve covers, then it would be smoking and or making some kind of a mess. Hg
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 07-04-2005, 10:48 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
If its not the pcv sucking it away. Check to see if the rear intake rubber has squished out of place. Oil can run down the back of the block, over the back of the tranny, and the drive shaft will spray it all over the place. If this happens it usually doesn't leave a puddle. You should see oil all over the rear of the car.
Old 07-04-2005, 10:54 AM
What with oil prices and all, maybe someone is syphoning it while you sleep. lol
Old 07-04-2005, 11:21 AM
edge's Avatar
Time is short, are you ready?
This goes in the "You never know" catagory
I know this is a long shot, but since it happened to me, it could happen to anyone. When installing my intake, the thin section of gasket seperating the #1 & 3 intake ports slipped. It slipped enough to cause the #3 side to draw in oil. Not enough to burn smoke, but enough to lose about a 1 quart per week. Note: the gasket in the picture was torn when removing the intake.
Check your plugs for signs of fouling. If you find only one, this could be your problem. Good luck, Ed.
Old 07-04-2005, 07:20 PM
4doorjoe's Avatar
oil consuption
THanks guys i will check all the above you have been a great help
Joe sammut
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 07:14 AM
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 08:39 AM
Oil Temperature and oil types (long) TurboS10 Engine 36 03-01-2005 02:51 PM
Oil Preshure ve3ham Engine 9 10-28-2004 03:36 PM
Should I change my oil? 48Man Engine 2 01-29-2003 08:28 AM
