Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Oil consumption due to possible sucking oil from intake valley..signs ?
Old 07-30-2010, 12:31 PM
27 t's Avatar
27 t 27 t is offline
WHO WHAT ME WAIT I DON'T KNOW.
Last journal entry: Door skins removed
this is how i would ck for an internal vacuum leak back in my jeep days this was a very common problem on the 318 = 360.. remove and plug pcv remove and plug breather.. take a vacuum gage with the large adp install into pcv grommet in the valve cover.. start the eng bring up the idle a little and see if the gage pulls a vacuum.. if you have a vacuum than more than likely you intake gasket is leaking... anyone disagree would it work on a sbc....
