Originally Posted by 27 t
this is how i would ck for an internal vacuum leak back in my jeep days this was a very common problem on the 318 = 360.. remove and plug pcv remove and plug breather.. take a vacuum gage with the large adp install into pcv grommet in the valve cover.. start the eng bring up the idle a little and see if the gage pulls a vacuum.. if you have a vacuum than more than likely you intake gasket is leaking... anyone disagree would it work on a sbc....
Thanks for the tip... Car going back next week, hopefully they will find it.
Thanks again for the reply....
