Oil or coolant? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2011, 09:21 PM
Ed and Cami's Avatar
Last journal entry: New cluster
Oil or coolant?
Just finished some exhaust and emissions parts replacement. Was hoping it would eliminate the problem, but, no. Getting some kind of oily(?) film all over the inside of my windshield. As a result, I can't drive the car because I can't see where I'm going, after a few minutes. Could it be that I need to check my heater core? Radiator and all hoses are new. The car is an '83 Camaro, so, in for a not fun time if I have to do this.
Thanks for any input.
Old 06-15-2011, 09:59 PM
Wiki Edits: 31
I put a truck into a telephone pole from a windshield smeared with power steering fluid on a bright and sunny morning. Not fun.. I would check there first.. Oil or coolant could also do it, but power steering runs at a high pressure and can atomize like that a lot easier
Old 06-15-2011, 10:13 PM
Just had a thought. Do you think brake fluid would do that? Also, not sure how power stg. fluid would get inside. Oh, well. Back to the wrenches tomorrow.
Old 06-15-2011, 10:27 PM
Wiki Edits: 31
just noticed you said inside. Has to be a leaky heater core. nothing else could do that.
Old 06-15-2011, 10:39 PM
Must be a small leak, though. I usually can smell something like that. Well, been thinking about it the last few days and think I'll have to agree with you. But, when a car has been through what this one has, I guess ya gotta expect some things.
Now, if I could just find an easy way to change some gaskets without pulling the engine.
Old 06-16-2011, 05:17 AM
heater core
It is the heater core . It only takes a pin hole to let vapors escape and get on the windshield and it will only get worse until you have a puddle of coolant on the passenger side floor board. Soooo, make plans to replace the heater core. I replaced the heater core in my '91 S10 Blazer yesterday. The heater cores will usually last about 20 years if the antifreeze is replaced every two years. The replacement heater core was entirely made of aluminum. Aluminum heater cores are better although copper/brass alloy with lead solder may be a little stronger. However, with proper cooling system maintenance, heater cores do not have to be bullet proof.
The GM heater cores through 1995 were copper/ brass alloy with lead solder. Today, OEM replacement and aftemarket replacement heater cores are made of aluminum alloy with EPA approved aluminum alloy solder. Aluminum heater cores are used today because some people, who don't know any better, still use Dex-Cool long life antifreeze. Dex-Cool long life antifreeze suposedly has better protection for aluminum engine components for long intervals between coolant changes. It is best to use green antifreeze and change it every two years.
Other problems with the heating system are the non-conductive plastic dash parts that do not offer good grounds to reduce electroysis. Electrolysis is caused by stray electrical current induced in the cooling system by depleated antifreeze and bad grounds. Use a digital VOM and check the voltage in the coolant to ground and if it more than 0.3, you may have an electrolysis problem. A high coolant flow rate through the heater core will also cause heater core failures. That is why the automakers use heater hose quick-disconnects with flow restrictors. Always use the quick disconnect fittings with flow restrictors on the heater hose at the instake manifold connection.
Old 06-16-2011, 08:06 AM
Wiki Edits: 27
heater box
I don't know about your camero. In those years I was into 5.0 mustangs. If your heater box to firewall is not sealed tight engine compaartment fumes can be drawn inside. A lot of Foreign cars are noted for having interior plastic parts that outgass , when the interior gets hot. those vapors condense on cold surfaces like windshields and side glass. leaving a gummy residue. also some american cars steering wheels get gummy after a few years.
Old 07-25-2011, 11:02 AM
Sorry I haven't been around in a while. Thanks for the info. Pretty sure I need to replace the heater core. Alreay replaced the steering wheel. Original one was old and feeling gummy, not to mention bigger than I want.
Also need work on other areas, like trans, rear, engine, interior, etc.
No, if I bought a new car I'd never get what I want.
Old 07-25-2011, 12:55 PM
malc's Avatar
Living At The Speed Of Life
83 Camaro, thatīs a fun job changing out the heater core.
Be prepared for skinned knuckles.
Old 08-18-2011, 12:14 PM
Got the heater core out. Yes, I know. Working takes away from spare time. Heater core seems okay, so I reconnected it into the system and fired her up. All that work to find out that all I needed to do was replace a hose clamp that wouldn't clamp. Aargh!!!
Old 09-22-2011, 01:41 PM
We have returned. Found out last week after work that I needed to change the heater core. Night and when the lights hit the windshield I was totally blind. Not a good feeling! Since I have the dash apart, I was wondering if anybody might have a gauge panel they'd like to get rid of. Looking for the gauges, tach included, with speedo that goes higher than 85. I would prefer the 145 but would settle for 115. I have idiot lights now. Yech!
Oh, yeah, forgot to mention that I would prefer to deal with somebody in the Denver, CO area, so I can come out and get it.
Old 09-22-2011, 03:40 PM
malc's Avatar
I didīnt take the dash apart, took it out from underneath,
passenger side.
Gauge clusters at Hawks Third Gen.
Old 09-22-2011, 09:23 PM
Thanks for the link, malc. Looks like they might have what I need. E-mailed them, but gonna call them in the morning. Do you deal with them a lot?
Old 09-22-2011, 11:58 PM
malc's Avatar
Iīve had quite a lot of parts off them,
including a gauge cluster.
You might like to try GM Sports Salvage or Youngs FBody Motorsports.
Old 09-29-2011, 03:00 PM
Okay, the part is expected to be delivered Saturday. I believe I need to change the oil pressure sending unit and temp sending unit, right? Anything else to get it to work?
red coolant mitmaks Engine 6 08-30-2010 08:43 PM
old coolant mitmaks General Rodding Tech 9 07-05-2009 08:50 AM
Coolant TokenJo General Rodding Tech 1 05-06-2009 05:03 PM
Coolant Dilemma! Ok to use Green coolant with Red coolant? mgold Hotrodding Basics 6 03-31-2009 05:37 PM
npg coolant mancinator Engine 0 07-09-2004 02:58 PM
