Oil Cooler?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2002, 12:31 PM
Dave E Shank's Avatar
Post Oil Cooler??
HEY: Have any of you guys run an oil cooler for street use???? Dave E Shank
Old 10-31-2002, 01:14 PM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Thumbs up
Yes they work as well as a trans cooler.If you get one, get a filter relocater and put 2 filters on it. Is this for a sbc? You will probably hear alot of inputs on this one.
Luv the smell of NITRO in the morning.
Old 10-31-2002, 05:02 PM
Canzus's Avatar
a red wool sock on his dinger
Post
Most of the factory hotrods from Ford are
using oil coolers these days, I don't know
about GM or DC...
Old 10-31-2002, 05:26 PM
Last journal entry: Doors
Post
I baught a 87 suburbun with a chevy 350 in it, to my suprise it had an oil cooler in it and it looked origonal, Since it comes stock on a suburban i would think that it is a good idea to have one
Old 10-31-2002, 05:51 PM
Last journal entry: Some pics
Post
Engine oil or tranny cooler? Alot of the towing packages include a tranny cooler.
Old 10-31-2002, 06:36 PM
Post
At first i thought it was a tranny cooler then when i went to pull the engine out of it there were two cooling lines going from the cooler to an adapter on where the oilfilter goes, it was deffinatly an oil cooler
Old 10-31-2002, 10:10 PM
4 Jaw Chuck's Avatar
Post
Unless your towing or dragging/racing it's unnecessary and possibly even detrimental unless it has a built in thermostat to prevent overcooling. Oil is required to run over 200 degrees or the water will never boil off from the blowby.
If you have a problem then go ahead but install a temp gauge first to see if you actually need one. You will need to mount a probe in the pan or on the dipstick, I use a type k thermocouple and some crazy glue to attach it to the dipstick for testing.
Most high perf applications don't require one unless you run it hard all the time.
— Han Solo
Old 11-01-2002, 08:00 AM
1meancuda's Avatar
At a loss for words
Post
Chuck makes a good point there. I would install the gauges first (monitoring engine vitals such as these is always a good thing in my mind! ) and see if you actually need it or not. I'm going to do this exact thing on both my daily driver and my 440 when it's done.
