oil coolers - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2010, 11:18 PM
oil coolers
hello, all, i have seen many different topics on the net concerning the use of oil coolers on a sb chev, what i had seen was kinda of a kit the bolts onto the oil filter housing, lines run to in front of the rad to a cooler and the oil filter just screws on like normal, has any body had good success or is this another urban legend deal,,,,,,,,if so are there any better kits then others???, thanks again,,,,,,,
Old 09-03-2010, 12:05 AM
SSedan64's Avatar
Those are called Sandwich adapters, fit between Filter & Block. They work fine. The flat Stacked Plate type coolers are more effecient than the round Tube type coolers.
Old 09-03-2010, 12:12 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I would suggest a thermostatically controlled type. This allows quick oil warm up before the oil is diverted to the cooler.
There are the units like you mentioned that sandwich the adapter between the block and filter (THIS one is by Derale), and there are remote filter mounts that move the oil filter(s) to the fenderwell, for example. The cooler lines are plumbed off of the remote filter mount.
The "stacked plate" type of cooler is efficient but a bit more costly than the fin and tube type cooler.
Lines can be as simple as clamped rubber hoses (designated for oil/cooler use) to AN fittings and braided stainless lines, from Earl's or Russell to name two.
Besides Derale, there's Hayden, B&M, Flex-a-Lite, PermaCool and others that you can look for.
Is it no good to have a High volume oil pump? Calderone Engine 17 01-31-2008 06:26 PM
Windage trays ernkazern Engine 25 09-18-2007 04:49 PM
oil leak rb8179 Engine 11 06-03-2006 04:07 AM
Excessive oil under valve covers in SBC? TVR383 Engine 13 11-21-2005 01:48 AM
Oil Preshure ve3ham Engine 9 10-28-2004 03:36 PM
