Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - oil dipstick
Thread: oil dipstick
Old 12-26-2012, 04:02 PM
mr4speed mr4speed is offline
If it is on the right (drivers) side it should be anywhere between 1968 to 1985. would have to look at the casting date on the back of the block. Should be a short tube that presses into the block. You should be able to pick one up at any speed shop in the USA, as this is the most common motor in the world.
