oil dipstick - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2012, 03:12 PM
oil dipstick
I have a 350 chevy, the oil dipstick is on the right.Can you tell about what year the engine is ? is there a tub before the engine block for the dipstick ? how long should the dipstick be ?
Old 12-26-2012, 04:02 PM
If it is on the right (drivers) side it should be anywhere between 1968 to 1985. would have to look at the casting date on the back of the block. Should be a short tube that presses into the block. You should be able to pick one up at any speed shop in the USA, as this is the most common motor in the world.
Old 12-26-2012, 09:49 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
IIRC 1980- back SBC were driver side. At least some SBC engines switched to a passenger side dipstick in 1981.
But in any event, the dipstick location will not tell you anywhere near as much as the casting number, date code and suffix code will tell you. More here.
Oil on Oil filler cap NOT on dipstick. afsog Engine 8 01-26-2010 05:50 PM
help with oil dipstick chewyscool Engine 2 12-14-2008 10:47 PM
Clean oil leaking, dirty oil on the dipstick? frankenvette Engine 7 10-02-2006 10:06 PM
Oil dipstick Novaman78 Engine 9 08-05-2004 10:58 PM
Oil dipstick 39chevy Engine 2 04-26-2004 11:53 AM
