Oil dipstick
Is there a difference in the oil dipsticks from a car and truck engine. The engine im referring to is a 1986 SBC 305ci it is out of a truck, and i don't have a dipstick so I cant see if the one from a car is shorter or longer. Man at parts store said one from a truck is longer but why? They are the same engine right?
DIP STICK
I'd change the oil, then check it with the stick you've got. If it reads to the full mark, you're OK, IF IT DIDN,T, I'd go to a dealer, and buy a stick and tube for the car I have. Make sure you check it to assure its correct. You know, when you run out of gas, the engines, Looses water, it gets hot, but it may work well after you solve the problem. But when they run out of oil, well, they're just need the same. Better safe than sorry. lol
thats just it i don't have a dipstick im rebuilding the engine and don't even have oil in it yet. Im trying to figure out if i can save money by pulling one off of another 305 or should i buy one. I know im not saving much but a little money saved here i can use on something bigger in the future.
Those cheap chrome mr. gasket dipsticks are only about $7.
Are there diffrent size diameters or something because my parts stores have a 5 qt dipstick but only goes to a 79 model.
Can you see the model # on the block? would be on the drivers side, on the back of the engine (i think, cant remember now)
Mine is a 1986 LG9, passenger side dipstick, measures approx 25 1/2" ( couldnt get an exact measurement due to the dipstick having a slight curve in it) I measured from the top of the cap to the end of the point. ______ < top of cap where the ? handle connects |...|...| ....|.... (ignore the dots) hope that helps |
Yeah that helps. Thanks. My uncle had an old dipstick and tube that the dipstick was broke and i tired to see it that would work but the tube was to big around. The dipstick on my engine is a pass side. Is the pas side and driver side different?
