oil filter
i just changed to the mr gasket screw on oil filter adapter ,hope i did it right now what oil filter do i use??? thank you if you can help
I have never used one, but any filter where the gasket will stop on the intended surface will work fine, I bet whatever kind you were using before will work ok.
Any that will fit, except Fram, they %$#@.
Vince |
| All times are GMT -6. The time now is 09:48 PM. |
