Oil filter adapter plate??
Ive got my oil filter adapter plate off my 350 when it was built. I notice that there is a washer in it with a spring and then a plastic piece. If i take this out it leaves an open hole. You can see the plastic piece when oil filter is off. First what is this for? And can it hurt anything if i leave it out? I'm thinking its some kind of bypass but im not sure how it works. The problem is if its needed i have to find a new spring as the original is so rotted it crumbled in my hand while cleaning it up. Which means i have to find the correct rate spring i would think.
Or you can put a pipe plug in it with a little epoxy. This way all the oil goes through the filter. However, you will have to run a good filter and change more often. Most race type engines are like this.
Thanks guys i appreciate your input. Ive seen the ones that eliminate the bypass at jegs. Im just not sure, would my oil pressure change or the flow rate change? Why is there a bypass to begin with? I think im going with the one that Engineczar put the link up for thank you very much for the link BTW
I have been searching for several days for one of these and kept coming up empty. HOTRODDERS RULE
The bypass valve is there to protect the filter from excess pressure. On a cold start, the oil is thicker, and oil pressure can go way higher than normal. Some filters can't take the excess, and will blow out. The bypass valve prevents this.
| chevy 350 oil filter housing help | briansansone | Engine | 10 | 10-24-2010 12:39 AM |
| oil filter blows out | sik400 | Engine | 17 | 02-01-2008 05:37 PM |
| Oil Filter Mount | crusherdbuzz | Engine | 1 | 05-07-2007 03:17 AM |
| Oil Temperature and oil types (long) | TurboS10 | Engine | 36 | 03-01-2005 01:51 PM |
| Is metal in the oil filter a bad thing? :( | TurboS10 | Engine | 26 | 09-11-2004 08:33 PM |
