oil filter mount, does it get a gasket? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2003, 01:22 PM
Gino Fultano's Avatar
New Member
ok my engine block didnt come with the oil filter mount attached, my question is does it need a gasket? should i use some sort of sealant around it? or just bolt it on and go. thanks in advance.
Old 08-23-2003, 02:36 PM
BOBCRMAN@aol.com's Avatar
Depends on the motor what do you have?
Old 08-23-2003, 04:39 PM
Vern Bradford's Avatar
Gino,
If you motor is just you standard chevy V-8 it requires no gasket, the seal is provided by the filter itself.
Are you kin to Bob?
Vern
