-   -   oil filter relocation (http://www.hotrodders.com/forum/oil-filter-relocation-188927.html)
peppers 12-10-2010 04:50 PM
I am relocating my oil filter, does it matter if the filter is upside down or side ways for the oil pressure to be correct? :thumbup:
matts37chev 12-10-2010 05:56 PM
it doesnt matter,try to make it easy for you to get at and change
also somewhere that it might get some cool air (at least keep it away from heat sources) would be best.
peppers 12-10-2010 06:13 PM
thanks
thanks, that is what I am doing, moving away from a header! :thumbup:
matts37chev 12-10-2010 06:24 PM
i would also say, use a good quality filter with an anti-drainback valve if you end up mounting it sideways or upside down
eloc431962 12-10-2010 06:45 PM
X2 you will want the "ADBV" don't like or want those dreaded dry start up. :sweat: :pain: :smash:
Cole
beertracker 12-10-2010 07:26 PM
How do you relocate a oil filter? Are there kits to buy for this? I may have to do this also since I am installing headers.
BT
ericnova72 12-10-2010 07:34 PM
Yes, there are kits, contain an adapter to replace the stock filter that has hose ports, a pair of hoses and fittings, and a remote filter mount. Trans-Dapt is one I know of off hand, Moroso, Canton, Fram also has kits, and there are several different companies in Jeg's or Summit.
techinspector1 12-10-2010 10:22 PM
I love those Trans-Dapt two filter units....
http://www.summitracing.com/parts/TRD-1222/
eloc431962 12-12-2010 06:23 AM
My T/A has a moroso on it seems to work fine, but i really like the "Trans-Dapt" Eric and Richard are talking about.
Cole
302 Z28 12-12-2010 08:34 AM
Avoid at all cost mounting it upside down. I have seen that on some new cars and it is an absolute bonehead idea IMHO. It makes a huge mess every time oil is changed.
Vince
eloc431962 12-12-2010 08:41 AM
Vince
X2 %100 With you Vince. Craziest thing i have seen with a oil filter. :drunk:
I don't like them on their side either IMHO.
Cole
Guy Hiltz 12-12-2010 08:47 AM
I had to use a remote oil filter kit on my 468 bbc '86 Monte SS.Between the kicked out oil pan sump and the 2 inch headers,there was no room to get the oil filter off.I made a couple of brackets and attached them to oil pan studs to hold the oil lines in place.I didnt want them rubbing where they shouldnt.Then I had hoses made from braided SS line,and I covered them with some old spark plug boot protector material and Thermotec wrap where they run by the block & headers.I mounted it behind the left side headlight.Heres some pictures;
http://i65.photobucket.com/albums/h2...carpics112.jpg
http://i65.photobucket.com/albums/h2...carpics082.jpg
http://i65.photobucket.com/albums/h2...ugwires008.jpg
Guy
matts37chev 12-12-2010 09:00 AM
well done,nice clean looking install, and i like where you put it.
you see so many of them on the firewall or somewhere that it will make a mess when you cange the filter and wont get any cool air :thumbup:
Guy Hiltz 12-12-2010 10:53 AM
Thanks for the compliment !!!
Its very easy to get at the filter,which is a K&N unit,with the anti drain back feature.I also reinforced the other side of where the bracket bolts to with a piece of thick aluminum.
Guy
eloc431962 12-12-2010 12:41 PM
1 Attachment(s)
I like your set-up also Guy. Here's how mine is on my T/A , guess you can see it on the passenger side. Pretty simple seems to work alright.
And also mine is a Moroso relocation unit.
Cole
