oil filter relocation - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2010, 04:50 PM
peppers's Avatar
I am relocating my oil filter, does it matter if the filter is upside down or side ways for the oil pressure to be correct?
Old 12-10-2010, 05:56 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
it doesnt matter,try to make it easy for you to get at and change
also somewhere that it might get some cool air (at least keep it away from heat sources) would be best.
Old 12-10-2010, 06:13 PM
peppers's Avatar
thanks
thanks, that is what I am doing, moving away from a header!
Old 12-10-2010, 06:24 PM
& matts38chev
i would also say, use a good quality filter with an anti-drainback valve if you end up mounting it sideways or upside down
Old 12-10-2010, 06:45 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 you will want the "ADBV" don't like or want those dreaded dry start up.
Cole
Old 12-10-2010, 07:26 PM
How do you relocate a oil filter? Are there kits to buy for this? I may have to do this also since I am installing headers.
BT
Old 12-10-2010, 07:34 PM
ericnova72's Avatar
More for Less Racer
Yes, there are kits, contain an adapter to replace the stock filter that has hose ports, a pair of hoses and fittings, and a remote filter mount. Trans-Dapt is one I know of off hand, Moroso, Canton, Fram also has kits, and there are several different companies in Jeg's or Summit.
Old 12-10-2010, 10:22 PM
techinspector1's Avatar
Wiki Edits: 326
I love those Trans-Dapt two filter units....
http://www.summitracing.com/parts/TRD-1222/
Old 12-12-2010, 06:23 AM
eloc431962's Avatar
Wiki Edits: 37
My T/A has a moroso on it seems to work fine, but i really like the "Trans-Dapt" Eric and Richard are talking about.
Cole
Old 12-12-2010, 08:34 AM
302 Z28's Avatar
Avoid at all cost mounting it upside down. I have seen that on some new cars and it is an absolute bonehead idea IMHO. It makes a huge mess every time oil is changed.
Vince
Old 12-12-2010, 08:41 AM
eloc431962's Avatar
Wiki Edits: 37
Vince
X2 %100 With you Vince. Craziest thing i have seen with a oil filter.
I don't like them on their side either IMHO.
Cole
Old 12-12-2010, 08:47 AM
Guy Hiltz's Avatar
I had to use a remote oil filter kit on my 468 bbc '86 Monte SS.Between the kicked out oil pan sump and the 2 inch headers,there was no room to get the oil filter off.I made a couple of brackets and attached them to oil pan studs to hold the oil lines in place.I didnt want them rubbing where they shouldnt.Then I had hoses made from braided SS line,and I covered them with some old spark plug boot protector material and Thermotec wrap where they run by the block & headers.I mounted it behind the left side headlight.Heres some pictures;
Guy
Old 12-12-2010, 09:00 AM
& matts38chev
well done,nice clean looking install, and i like where you put it.
you see so many of them on the firewall or somewhere that it will make a mess when you cange the filter and wont get any cool air
Old 12-12-2010, 10:53 AM
Guy Hiltz's Avatar
Thanks for the compliment !!!
Its very easy to get at the filter,which is a K&N unit,with the anti drain back feature.I also reinforced the other side of where the bracket bolts to with a piece of thick aluminum.
Guy
Old 12-12-2010, 12:41 PM
eloc431962's Avatar
Wiki Edits: 37
I like your set-up also Guy. Here's how mine is on my T/A , guess you can see it on the passenger side. Pretty simple seems to work alright.
And also mine is a Moroso relocation unit.
Cole
Oil filter stuck joefromcocomo Engine 9 03-28-2010 09:56 PM
454 BB Oil Filter Conversion Blanceman Engine 3 02-27-2010 07:35 PM
fram oil filter lower oil pressure elvis 66 chevelle Engine 33 09-14-2006 04:36 PM
Ever had an oil filter cost you 110 dollars? Read this crappy story. killerformula Hotrodders' Lounge 30 10-10-2004 10:50 AM
Should I change my oil? 48Man Engine 2 01-29-2003 07:28 AM
