Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Oil Filter relocation kit...
Old 04-10-2006, 10:19 PM
Elevinpointsixtoone's Avatar
Elevinpointsixtoone Elevinpointsixtoone is offline
Did you have oil pressure? Is there fresh oil in the rocker area? It may be you had been just by-passing the filter altogether. There is a pressure releif valve that if I remember right, will allow oil to bypass the filter when there is too much back pressure by going through the filter. Its a little deal right there on the block/filter mounting pad. It could be stuck open or you have a blockage in the filter lines or maybe you have the wrong filters on the remote mount meaning the holes in the filter don't line up with the holes in the mount causing it to be sealed off.
