Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - oil filter relocator??
Old 02-07-2003, 06:28 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Post
Flow rate is actually pretty slow so any full-flow hydraulic fitting should work fine. I have the same problem w/ my Willys and have pretty sharp 90s on the block w/ no porblems. There are many, much sharper turns inside the block than you will ever have on the outside!
