Oil filter stuck
I have a stuck oil filter on a pontiac 400. The filter's tin has ripped off up to where the filter meets the oil pad on the block. The "guts" of the filter came out as well as a plate but the plate with holes is still screwed onto the block. I have tried using vice grips to twist off remains of filter with no luck and I have no idea why the filter is stuck. I bent one side of the plate down thinking it would release the seal and loosen. I replaced the filter last time and i dont think it was cross threaded. The filter never leaked. I'm thinking about cutting the plate with a dremmel. Any thoughts? joe
Hmmm?
Well if anything you can always replace the oil filter piece from another 400 block. I think it should have 3 or 2 bolts holding it.
Did you over heat the engine? |
I would take a hammer and a wide dull chisel and try to spin the filter base off.
Farmer fix
try the two pin wrench that came with your side grinder - if you are lucky it might fit , if not make one with a piece of metal and a couple of bolts.
Are you SURE you're turning it the right way? Just kidding!. Last time I was in Harbor Freight, I saw an oil filter wrench with vice grip "locking", and large, curved, "gripper", jaws; pretty mean looking tool. It looked like it would remove any part, of any, stuck on oil filter; or could be used in a midieval dungeon. Butch/junior stocker.
| Welch Plug - In or Out? | Gun Laker | Engine | 5 | 11-03-2009 07:50 AM |
| Converting late model 98 block to standard oil filter fitting | TNshadetree | Engine | 5 | 07-03-2009 08:00 AM |
| Any tricks to get off a STUCK oil filter?? | 78SilverShark | Engine | 81 | 05-19-2008 04:19 PM |
| fram oil filter lower oil pressure | elvis 66 chevelle | Engine | 33 | 09-14-2006 04:36 PM |
| Should I change my oil? | 48Man | Engine | 2 | 01-29-2003 07:28 AM |
