Oil Filter Stud question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2004, 05:13 PM
Pittbull's Avatar
On older model Chevy 350 Does the oil filer stud press in or screw in?
I noticed me project block is missing the oil filter stud
Any help is greatly appreciated.
Old 12-01-2004, 09:58 PM
BOBCRMAN@aol.com's Avatar
The oil filter on older Chevy engines does not use a stud.. It uses a two bolt adapter that screws into the filter base area. Early blocks that had the old can filter also use an adapter, tho a different design.
Old 12-01-2004, 10:13 PM
POOR SEND HELP!!!
http://www.sdpc2000.com/catalog/317/...-and-Bolts.htm
Old 12-03-2004, 09:20 PM
Pittbull's Avatar
Thanks for the info guys I have solved alot of problems I was facing by getting a new block to day.And aagin thanks for the info
