Oil and Flat Tappet engines info - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-25-2013, 04:42 PM
acme's Avatar
Oils with enough Zinc
Here's some oils that has the amounts of Zinc|Phosphorous from Mobil 1. Any brand of oil that says 'For High Mileage' has a high amount of Zinc-Phosphorous in it. Notice amount of Zinc-Phosp. and the SJ and SL rating for the 'High Mileage' Mobil oil.
Valvoline's MAX Life has the same robust ZP also, plus Quaker State, Pennzoil. They have you covered for you anti-non-zinc Rodders
http://www.mobiloil.com/USA-English/...duct_Guide.pdf
flat tappet cam oil 0pyders Engine 8 05-17-2011 11:48 AM
ZDDP additives for flat tappet engines Carlos9 Engine 27 02-10-2009 06:34 AM
Which oil/additives for flat tappet cams? Sinister Engine 6 04-12-2008 03:15 PM
Break in oil flat tappet cam 71 c-10 Engine 5 11-17-2007 10:55 AM
Best oil for flat tappet cam Steve B Engine 10 09-24-2003 07:26 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
