Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - oil galley plugs
Old 01-30-2009, 03:50 PM
MorrisonLC's Avatar
MorrisonLC MorrisonLC is offline
Those are the little threaded ones, like about a 1/8" NPT? Did you replace them with new plugs when you built it? Are you using a good quality USA made plug with no thread flaws? Use non-hardening Permatex, you should have no problems. You're not just gooping sealant over the top of the plug, right?
