oil galley plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2009, 03:40 PM
oil galley plugs
Help! I've got a stroked 289 to a 349 high volume oil pump, and leaks. I've sealed the oil plugs on the back of the block with gasket sealer. Two are doing fine, but one keeps leaking at high RPM. Im getting tired of pulling the trans, clutch, and everything else related. What will seal this thing up? I start tearing down Sunday.......again. Thanks
Old 01-30-2009, 03:50 PM
MorrisonLC's Avatar
Those are the little threaded ones, like about a 1/8" NPT? Did you replace them with new plugs when you built it? Are you using a good quality USA made plug with no thread flaws? Use non-hardening Permatex, you should have no problems. You're not just gooping sealant over the top of the plug, right?
Old 02-04-2009, 05:21 PM
Thanks for the response. I took out the trany, clutch and related parts. previously the plugs were the problem because one of them wasn't run in far enough. That issue has since been fixed. I found out this particular leak is actually coming from the very corners of the oil pan gasket at the bearing cap. That's a new project. thanks again
Threaded oil gallery plugs on front of SBC CuttyGMachine Engine 5 10-30-2008 08:49 PM
Oil Covered Spark Plugs. Please Help!! jordan2011 Engine 3 10-25-2008 06:28 AM
motor wont start spark plugs have oil on them 54chevy22 Engine 13 08-10-2006 09:28 AM
Oil Temperature and oil types (long) TurboS10 Engine 36 03-01-2005 01:51 PM
loose intake bolts & oil fouled plugs 68GEETEE Engine 1 09-26-2004 03:56 PM
