oil gauge gone high - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2010, 11:45 PM
oil gauge gone high
new engine on a 85 el camino . removed a 4.3 tbi installed a 350 carb now the oil gauge goes high on start up it has 60 psi i also used the old sensor n wont work any ideas or help. thanks
Old 10-15-2010, 01:18 AM
DoubleVision's Avatar
New engine, cold oil, oil pressure going up to 60 is normal. Cold oil is thicker so the pressure reads higher. The sending units should have swapped just fine, unless your using a HEI instead of the small cap TBI ignition system which means it likely won`t clear, if this is the case you can get a adapter with a elbow to clear it. What year 350 did you use? If in any doubt get a oil pressure sending unit for a early 80`s chevy truck as they all came with gauges then you should be able to test the wire to find out which is going to the gauge then connect the wire to the new sending unit.
Old 10-15-2010, 08:06 AM
bubbahotep's Avatar
My 86 Monte does the same using the orginal guage and new sending unit. It is pretty accurate though. 60 cold is normal, you should see it drop when hot.
My experience is that it works better in the lower readings (fluctuates) but usually just stays locked at 60 for a while when started. In the winter I always worry it's not working but it does move eventually.
Old 10-15-2010, 08:52 AM
Onefunponcho's Avatar
agree
I third their posts.
60psi is fine for a fresh motor and cold oil.
Old 10-15-2010, 08:46 PM
Cape Cod Bob's Avatar
Are u useing the proper oil ?
Old 10-16-2010, 12:28 AM
i am using the correct oil n yes i am using a hei instea now the sending unit is sideways is that a problem. and thanks for all the helpfull info.
Old 10-16-2010, 12:48 AM
FastOrange's Avatar
60 PSI is fine, My stock short-block with a stock oil pump reads 50 PSI on a cold start and thats with the 150,000KM on the bearings.
Old 10-16-2010, 12:53 AM
does it make a difference that the sending unit is sideways
Old 10-16-2010, 01:01 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
No, the sender could be upside down for all it matters. Sideways is fine.
Old 10-16-2010, 01:05 AM
cool thanks a lot it must be that i actually havent put it in gear or the road just turn it on and let it idle
Wickly high oil pressure deiselpower Engine 5 08-11-2009 06:10 PM
Smoke'n motor Red neck blazer Engine 25 06-09-2009 03:32 PM
High Oil Pressure 283 nickeldimerods Engine 40 08-24-2007 11:40 AM
Guages are dead gtipton Electrical 4 05-09-2007 10:14 PM
Oil Temperature and oil types (long) TurboS10 Engine 36 03-01-2005 02:51 PM
