Oil leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2010, 09:00 AM
George Humphrey's Avatar
Last journal entry: '64 Buick Special
Oil leak
My new Year One 350 400 hp Vortec got started and had a water pump leak, I had to grind down one of the timing cover bolt heads to fit the short pump on it, I restarted and it's flinging oil, could the seal on the crank be shot?, I've had the motor sitting since august last year.
Old 04-20-2010, 08:55 AM
delawarebill's Avatar
also the oil pan front seal...
they could have made the mistake of putting the skinny seal in and it willl not seal.. u can replace that or put some rtv on finger and squeeze it in to see if thats the problem... then pull the pan and replace the seals..
Oil Leak NickO Engine 5 07-02-2007 07:18 AM
Oil Leak 49dream Engine 12 09-11-2006 08:18 PM
clues needed for 460 oil leak cboy Engine 2 07-21-2006 02:32 PM
oil leak 4.8l ford Walker Engine 4 11-06-2003 08:30 PM
