I don`t think it`s caused by the oil leak. It`s common after the engine gets some wear on it after break in for the oil pressure to drop. Your oil pressure is excellant. Look on the passengers side at the 9 o`clock position of the harmonic balancer. You will see 2 bolt holes a couple inches away from it, one on top of the other, is there a bolt in the upper hole? If not this is where your oil leak is as the fuel pump push rod is in direct line of it.
If there`s no bolt use a short bolt dabbed with a little sealer, if the bolt is too long it`ll make contact with the fuel pump pushrod. |
Bolts there, oil seems to be coming from along the fuel pump, was just a little worried on the dipping pressure since I just built the motor .
I have degreased the engine compartment and will see if I can pinpoint the leak, also I am thinking on changing the pan gasket to a 1 piece instead of the 4 piece as I am thinking the leak if it is not from the pump gasket then it is from right where the front gasket meets the side gaskets |
This same bolt is sometimes removed and replaced temporarily w/a longer bolt to hold the fuel pump push rod back out of the way while the pump is changed. Sometimes if this is done, when the shorter bolt is put back in place, it will not be sealed or tightened enough. The results are a leak like you've described. Your oil pressure is OK, and the leak has nada to do w/it. Be sure that the filter is changed often during break in- if the bypass has been plugged in the filter mount (which it often- and rightly- is), a loss of flow from the filter picking up debris will cause a lower oil pressure, because having a blocked bypass is forcing ALL the oil through the filter. Last edited by cobalt327; 04-18-2010 at 06:23 PM. |
there is a bolt in both of the holes and I pulled the upper one and put some sealent on it, but the leak is still there fuel pump is covered with oil , pulleys belt are clean so is the timing chain cover, oil seems to be on both sides of the pump and right in the front upper section of the oil pan on the passenger side.
| Oil Leak | NickO | Engine | 5 | 07-02-2007 07:18 AM |
| Environmentally friendly honing fluid. | F-BIRD'88 | Engine | 16 | 07-01-2007 10:06 AM |
| Oil Leak | 49dream | Engine | 12 | 09-11-2006 08:18 PM |
| clues needed for 460 oil leak | cboy | Engine | 2 | 07-21-2006 02:32 PM |
| oil leak 4.8l ford | Walker | Engine | 4 | 11-06-2003 08:30 PM |
