Oil Leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2011, 09:36 AM
itsandre's Avatar
Oil Leak
Hey all, Me again.
Been busy trying to button up some issues with my build SBC 350.
Runs awesome but unfortunately I have an oil leak at the rear of the engine.
Like everyone first thing that comes to mind is the worst and that would be the rear main seal.
When installing the seal I did install it the correct way meaning the neoprene lip seal facing inward and I also offset the seal so it didn't line up with the bearing block seam. I did not add sealant on the ends of this two piece seal though. Is this something I should have done?
Today I am going to start with re torquing the oil pan first to see if this will fix the leak. When it first started I snugged up the two oil pan bolts on either side of the pan just before it starts to curve around the journal. You know the last two larger bolts. It seems that maybe I've over tightened these to try and stop the leak and perhaps made it worse.
This is my theory anyway and hopeful thinking.
I will back off on these two bolts and just snug very little.
If that doesn't cure the problem then I guess I will have to remove the rear main seal and replace it.
I know pretty much the procedure and having the engine on a test stand will make this much easier. Do I need to add a sealant on the ends of this seal?
Does any of this make sense to anyone? Is it possible that I have over tightened these? Looking at the area with a flashlight I can see the drip forming right at the edge of the bottom of the pan lip where it wraps around the crank. If it where the rear main seal, wouldn't oil be seeping onto the journal and slinging all over the place. I don't see any evidence of that happening. Just a small drip forming at the edge of the pan.
Being a newbie I feel kinda stupid asking this but I quess we all get stupid at times Right?
Old 03-02-2011, 09:58 AM
SSedan64's Avatar
That does sound like the Pan & not the Rear Main. Over tightening may have deformed the Pan rail bolt hole area & it may need to be peened flat. At least it's on a Stand and not installed.
If the RM Seal isn't leaking you may not want to mess with it. It is best to dab a spot of sealer on the seal ends tho'.
Old 03-02-2011, 10:42 AM
itsandre's Avatar
I backed off those two bolts and just hand snuged. It made a huge difference. Still a drip or two but no where as bad. Maybe the gasket will bounce back but who knows. Worse case I remvove the pan and replace that gasket. This is not going into the engine bay untill all the issues are addressed. I still need to replace the damper. I bought a used one and it shifted back a liitle towards the timing cover. I've read that if these are 10 -15 years old the rubber get dry rot and they do go bad. New one on the way.
Yea on this stand that I made otta 2 by 4's and scrap plywood works really well. Cost me $12 bucks and a little enginuity.
I'm going to do a video and post it today I think. I'll post it on youtube and post the link here. I tried the other day but didn't work. I got it figured out now so look for it.
Thanks for the input
283 oil leak lt1tyrell Engine 6 06-22-2010 08:34 AM
Frustrating Powerglide Leak or Torque Converter Leak? 67Elcamino Transmission - Rearend 2 08-26-2009 10:16 AM
Oil Leak pjarrett Engine 11 07-03-2006 10:38 AM
Ford power steering box leak (steady leak) StevenC Suspension - Brakes - Steering 7 06-17-2005 08:36 AM
400 SBC oil leak gearhead77 Engine 4 08-25-2004 09:15 AM
