Oil Leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2012, 08:33 AM
Oil Leak
got a oil leak. it coming from a hole in the block, next to the timing chain cover, behind/below the alternator. this is a chevey 350 engine.
Can so one tell me what those two holes are for?
Old 07-29-2012, 09:31 AM
Crosley's Avatar
Wiki Edits: 1659
moving from introduction forum to basics.
thanks.
Old 07-29-2012, 10:22 AM
There are holes in the lower front of block that are used for misc brackets. The hole goes through the block to the area where th fuel pump push rod is. You must have a bolt in this hole but be careful. If you install too long of a bolt it can hit the push rod.
Old 07-29-2012, 11:37 AM
BigEd36's Avatar
The 2 holes John is talking about (there's a matching pair on both sides) are where the motor mounts bolted to the engine in the early '55-'57 cars, they didn't have side mounts back then. I believe the pickups used those a number of years after the cars had gone to side mounts. As John said, use a short bolt with some sealer to close the oil leak. TIP: When you're changing a fuel pump, take the bolt out, use a longer bolt to just snug up finger tight against the fuel pump pushrod (with it pushed up all the way) to keep the pushrod from sliding down while you install the pump. DO NOT forget to remove the longer bolt before you start the engine!
Oil leak between oil filter adaptor plate and block HotRodMan Engine 3 04-23-2011 10:36 PM
Oil Leak de64 Engine 1 08-24-2007 02:37 PM
Milky Oil and oil leak Parisienne70 Engine 4 04-27-2007 07:25 AM
Oil leak bigford556 Engine 10 02-03-2005 04:17 PM
HV oil pump makes oil filter seal leak WBrianS Engine 13 11-20-2003 01:56 AM
