Oil leak 350 Transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2010, 09:17 PM
I have an oil leak coming out of the speedometer cable attachment point on the transmission case. I have replaced the speedometer gear part with o- ring that slides into the case and replaced the speedometer cable. Still drip drip drip.
Any suggestions what I might try to clean up this mess???
[IMG]CIMG9244 JPG[/IMG]
Thank you,
Richard
Old 04-05-2010, 02:07 AM
ericnova72's Avatar
More for Less Racer
There is a small lip seal that seals around the shaft of the plastic speedo output gear. It is pressed into the end of the "bullet" that the speedo cable attaches to. It is in the ID of the same end that is threaded for the cable.
Oil Leak Chevy 350 pre 1986 longt Engine 6 02-07-2007 08:54 PM
Jiffy lube rant: what would you do? killerformula Hotrodders' Lounge 35 02-16-2006 06:07 PM
Rear of engine oil leak 350 western star Engine 5 07-13-2004 03:32 AM
oil being sucked threw the pcv valve on my 350 sb.. Robbie Engine 23 05-08-2004 09:12 AM
350 Oil Leak Dave E Shank Engine 1 10-14-2002 06:13 PM
