oil leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2006, 07:58 PM
inquiring_mind2's Avatar
a shade tree mechanic
oil leak
Hello,
I have a friend that has a 94 GMC Sonoma 4x4 with a 4.3 V-6. It is going through about 3 quarts of oil a day. I thought it might be the rear main seal. I was wondering if anyone new if it was a one piece or a two piece rear main seal. And if anyone has any other ideas of what it might be. any help would be greatly appreciated
Thanks,
Chris
Old 02-24-2006, 09:46 PM
rick_458's Avatar
Wookie
If he is Leaking that much on the ground he would have a HUGE puddle ( 5-6' in Dia) on the driveway.
He will probably be burning it possibly with Aligned rings or very bad valve seals.
for a leak check the Oil sensor, or a warped valve cover, as well as the rear seal in the trans area.
Get a few cans of Carb cleaner and try to clean the oily looking areas on the engine, then try to see exactly where it comes from
Old 02-24-2006, 09:59 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
It is a 1 piece rear main seal. The 4.3 is for the most part a leak free engine other than the intake manifold end seals. Is it leaking onto the ground or is the oil just gone. Sometimes if the engine is burning it, you will never see it smoke out the tail pipe, its getting burnt in the cat converter. Hope this helps.
Steve
Old 02-25-2006, 12:32 AM
it is leaking on to the ground. or I should say it seems to only be leaking when you are driving it. There is oil all over everything underneath
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 06:14 AM
Oil leak at MSD distributor base? TVR383 Engine 2 10-28-2005 03:37 PM
Oil leak fred56 Engine 2 12-13-2004 12:45 PM
Oil leak still?? leastbay Engine 8 08-15-2004 12:41 PM
Tip of the day on oil additives that you need to read mcgyver-ky Engine 10 04-19-2003 05:17 AM
