oil leak around gear selector shaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2003, 12:51 PM
New Member
is there a good way to prevent a VERY small oil leak around the shaft where the shift linkage goes into the tranny on a th350? I might be losing a tsp every week, but I hate leaks.
Old 10-12-2003, 01:15 PM
Change the seal...........
There is a tool made for this........
It is made by KD
The seal is very inexpensive.
Remove the lever, take the tool and twist the screw in of the tool into the seal. The bolt in the end of the tool is turned and it pulls the old seal out. Put some lube (I use Vasoline) on the seal and slide it over the shaft. Take the silver socket and tap the seal to the bottom. Reinstall the level....done deal
